That looks fantastic Dan. Great work.
Shane
I’ll take ten of these and ten of the rotary gondolas. Get busy.
I’m sure Rooster will want some, he’s a sucker for tank cars especially if the trucks are equipped with metal wheels (https://www.largescalecentral.com/externals/tinymce/plugins/emoticons/img/smiley-wink.gif)
very neat work!
did you use acetone to smoothen the surfaces?
Korm Kormsen said:
very neat work!
Korm,
I printed in PLA and the only parts I’ve smoothed are the end caps. I used 3 coats of Rust-oleum Gray Filler Primer (sanding between coats). I will probably do the same with the flat sides of the end platforms but the rest of the parts should be fine with just paint (10 ft rule).
What diameter tubing is that? Is it styrene or abs or pvc? (I ask this because you could not have printed it and not smoothed it clearly).
Greg,
It’s Schedule 40 3" (3.5" OD) PVC. This is not a fully 3D printed model. If you check out the Thingiverse page https://www.thingiverse.com/thing:3239142 you will see a list of all that is needed.
Thanks, was just trying to get a feel for the actual size.
I did not realize that you had put the list of components on the thingverse site, very helpful.
I also did not realize Al Kramer sold complete trucks, will have to take a look at those, how do you like them as compared to Aristo or USAT?
In my research I found Tank cars made in many different lengths and diameters. The 3.5" OD pipe is 8’ 5.5" diameter in 1:29. I have ordered some 4" OD Aluminum pipe which at 9’ 8" will be closer to the 9’ 10"-10’ range of a General Service Car.
I bought these in bulk from him on eBay http://www.roll-ez.com/product/1pair-strongest-bettendorf-upgrade-freight-trucks/ . They are nice looking and super strong. However, I plan on shaving off the center caps and drilling them to accommodate bearings and working center caps.
Interesting bending jig there on Thingverse.
Added a control valve based on the New York Air Brake DB-60 and some holes in the reservoir to accept piping. Question for 1:29 folks, What size wire do y’all use for grab irons?
I personally use 3/64" but I model by eye and not to scale
But rooster, that must be off from correct scale by at least 0.000004" !!! what the heck? Oh the humanity!
this site has some interesting data on grab iron and piping dimensions: http://www.urbaneagle.com/data/RRstddims.html
VERY NICE 1/29.
So that’s 1.19mm. Thanks! That’s close to 17 Gauge (1.15mm) which I what I was thinking would be a good balance of looks/durability. 3d printed parts that small would be too fragile but 17mm Electric fence wire should work!
(https://www.largescalecentral.com/externals/tinymce/plugins/emoticons/img/smiley-cool.gif)
This post has been edited by ROOSTER : another useless post only to bump the count
A very nice job on that tanker Dan and a great use of the 3D printer.
Awesome work! Just downloaded the files. Ah, 3D printing and Xbees for the holidays. It is going to be a great Xmas (http://largescalecentral.com/externals/tinymce/plugins/emoticons/img/smiley-smile.gif)
Thanks Guys!
Keep in mind this is still a work in progress. I’m working on a jig to make grab irons and will add holes to accept them. Also, I bought some 4" OD Aluminum tube and will rework the parts for that size. Adds $$ to the build but closer to most common prototypical tanks. I figured out each PVC pipe car costs me $38.88 to build. The aluminum pipe will add $12.
