Last spring I purchased a tram or steam donkey engine from GRS UK. It had been put together by someone in europe - no idea who. It looked great running on Jerry’s (Naptowneng) SC&M RR.
I was told it had been built from a couple of LGB engine cabs - in fact the inside says “2077” which makes the part a “Daisy” cab.
I started converting it to battery r/c operation this week, and thought I’d post a few photos so anyone who wants a quirky little tram will know how it was done. Here’s the body, which is symmetrical and obviously 2 cabs back to back.
Inside you can see the cab back and front. There are windows in the ends. Whoever built it added a coal bin at the back (needs a fake load,) and side water tanks. You can also see the cutouts for the ‘daisy’ boiler that he filled.
The front has a smokebox and a pair of cylinders, plus those pretty lamps, which I am lighting with a couple of small LEDs.
Lots of rivet detail around the frame, which hides a Piko 0-4-0 mechanism.
And inside the bodywork is just enough to suggest the steam boiler and controls. The wires come from the motor - I have removed the skates and wheel pickups.
I think it is a neat little loco. It’s getting 4x18650 Liion batteries and a protection board, plus a Viper ESC (and a couple of 6A diodes to drop the voltage a bit.) I think the r/c will be an Orange DSM2 RX and my Deltang TX.
