Dave’s ADD must be kicking in.
On the build I have always liked the style of the Rico station that has been mass produced in other scales.
Also being from the B&O/C&O area I seemed to have gained a little influence from their structures.
ALthough not as large and grandious as I would like the model now measures on the main structure 15 1/2" deep and 49 3/4" long. The roof gives the station a footprint of 26 1/8" deep and 59 3/4" long.
Looking for suitable materials for the build and wanting to keep a family look to my rail I chose to use vynal siding for the main structure. This building so far has used 1 and 1/3rd sheets, first cut into 50" lengths and then ripped on my table saw to a scale 10" strip. This allows a 6" scale reveal on the laps.
After the maln structure was framed with 3/4" square stock the voides were filled with 3/4" blue foam.The vynal was then applied using whatever caulk was on hand. One tube was silicone and one was painters caulk. If you look at the passenger end of the station you’ll notice a void at the bottom of the walls. This will be done with cut fieldstone, if I can make it work.
Next up is the freight door I have done. This again was done with vynal ripped to a scale 3". All blue on the model is wood at this point. If you look at the freight door you’ll see I laid it in a diamond pattern.
The roof again was done with 3/4" stock and set at a 12/12 pitch. To get the roll on the lower end I used a 12"rim of a wastecan. The rafter tails were then glued and nailed with scrap pieces to reinforce the joints. The roof is designed to capture the walls when in place and is removable because of the size of the structure. To form the roof sheathing I used aluminium coil stock and rivited it in place. Yes I over sized the holes in the aluminium for expansion.
This will be covered using Richard Smiths’ method for shingle making.I’ll use 30# roof felt cut to 3/4" strips and notched every 3/8". I’m hoping for a slate roof look.
Hope this helps a little.
Dave
