Hey folks,
I wanna run an idea by you all. I was approached over the weekend to design and print some warehouse type lamp shades for a club member who is building an indoor Gscale layout and is using fiber optics to light it. It got me thinking about a lighting solution for a project I am working on for Pete Lassen. I need to make some small lights that need to stand off the project (yes I am being vague). I was going to use Pico or similar LEDs but even as fine as their wire is the pair of wires is still way to big to look like conduit and unless I put it in something even larger it wouldn’t be rigid. So I had a conundrum on how to light this and make it look right. Enter the fiber optics. I purchased 1mm fiber filament/cable. It fits nicely in 3/32 brass tubing which makes a nice looking conduit. I then designed a prototype light engine/generator that is on my printer as we speak that will bundle about 8 or less fiber cables and light it with a 5mm LED. I will use a solar powered dollar store path light for the solar cell and battery. Long story made longer and this will be a stand alone solar powered fiber optic lighting solution. It can give you several points ( I am thinking up to 8 or 9 filaments) per engine. And at least two engines would be able to be run off a single solar panel and battery.
My question from you guys is this, would you all think there would be a market for a stand alone solar powered light fiber optic light source for our hobby? Basically each building would have its own light source with maybe even a couple buildings being lit by a single solar cell/battery. It won’t be as bright as a single source LED but it would give us the option of lighting individual fixtures instead of individual rooms. And for things like exterior lighting like porch lights and what not. I am curios if this is worth me spending the effort to develop the product as something to market instead of a one off for my project. What I would do as a one of would be more rudimentary than something I would market as a package. I can also see developing the fixtures to go with it like various lamp shades, junction boxes and conduit, and housings for the solar panel and battery that would be a trackside detail. When i get Pete’s project done I will debut it and will get your guys further input.
