One of the most annoying things about sound-equipped steam locos is hearing the chuff and other engine sounds coming from under the tender. I have solved this problem on my Bachmann Shay and Climax locos by adding a second speaker in the stack.
Of course this negates the possibility of using the smoke units, but I never use them anyway. My imagination works much better.
If you want to try out a stack speaker, it’s a simple and inexpensive way to get a tremendous improvement in the sound. Here is how I did it:
I used the optional diamond stacks on both locos to allow using the largest possible speaker. The speaker is a 50mm diameter, 8 Ohm, 5 Watt unit. Here’s a front and back view and a link to the speaker on Amazon.
Just for comparison, here is the new 50mm speaker (right) beside the original Bachmann Climax speaker (left) that goes in the bottom of the fuel bunker.
I began by removing the top portion of the diamond stack. The two parts are glued together with the standard Bachmann plastic adhesive and can be easily pried apart.
I soldered leads to the speaker and ran the wires down through the stack. I use quick disconnect pins so that I can easily remove the stack if needed. I placed a bead of silicone caulk around the rim of the speaker and dropped it into the lower part of the stack.
I stuffed a small plug of fiberglass insulation into the bottom of the stack. This makes the lower stack a sealed speaker enclosure and intensifies the amount of sound from the top of the stack. You can also leave out the plug and let the sound behind the speaker reverberate in the smoke box. Try it both ways and see which effect you prefer.
I reattached the top of the diamond stack with a semi-permanent adhesive (Ailene’s Tacky Glue or equivalent) just in case I ever need to replace the speaker.
I ran the speaker wires through the boiler and connected them to the sound card. Some sound cards can support two 8 Ohm speakers in parallel (like the Phoenix P8 in my Shay) or have additional outputs for a second speaker (like the QSI Titan in my Climax.) The big advantage with the QSI is the ability to direct different sounds to either speaker or to mix them in any proportion between the two.
Fire it up and listen to the chuffs coming out of the stack! I think you’ll like the effect. My next experiment will be with smokebox mounted speakers for my locos with straight stacks. I’ll let you know how that works out.
Bob
