Since I don’t bend the Llagas Creek C215 NS rail insulating the sections happens with 1.5mm styrene pieces and industrial strength CA. Works very well on straight section, however turned out to be a different story in curves (min. 5ft). Expansion and contraction will do the rest, time to get some insulating clamps for those curves.
The only snag is the insulating material is flexible, which results in a slight kink at the joint and the gap between the two brass parts will/could close up . To fix that I insert a 1mm styrene shim in the gap and voilà … smooth joint.
PS excellent service from Split Jaw
