For the last month or so my DX5e has been misbehaving; intermittently loosing the radio link between TX and RX. It started out as a once-in-a-while problem but in the last few days it has become chronic, almost to the point of crashing a train today due to loss of control. I was going to post here to see if anyone had any ideas, but decided to Google the symptoms first. Glad I did because the first R/C forum post I read described my exact symptoms and a logical cause.
The radio will loose the link with it’s RX at seemingly random times. I found that tapping on the TX body would restore the link for a while. The post I read, which included a Youtube demonstration of the symptoms, showed me that it was easy to cause the link loss by tapping on the TX case or power switch.
It seems that Spekrtum uses a DPDT switch for main power. One pole of the switch powers the LED battery indicator while the other pole powers the actual transmitter. A poor solder joint on the switch causes power to be lost to the TX components while the LED indicator remains lit.
The fix was to open up the case, find the 6 pins for the power switch at the top of the main circuit board, heat each one and add a tiny bit of solder. Since heating all 6 joints I can no longer cause the TX to loose it’s link with the RX.
I am now a very happy camper
Youtube video (embedding was disabled): http://www.youtube.com/watch?v=Je764AvkRlQ
