I have been doing a lot of fishing on the Susquehanna River this year. Recently my fishing partner and I went right smack in the center of the Harrisburg area which we usually avoid because of the the boat traffic. However the water temp is cold and the fish are in the deeper holes there.
This area has an abundant railroad history. At one point there were 4 working bridges crossing within less than 10 miles of each other with 4 different railroads using 3 of them and one being a dedicated trolley line. The famous Rockville and the PRR is north of the city and still in use by NS. The CVRR bridge (not in use) was the first to cross the river at the city and was also used by the Northern Central RR which Abraham Lincoln rode on many times. The Philadelphia and Reading bridge is right next to the CVRR bridge and still in use by NS on it’s Lurgan branch.
The reason I’m sharing as my friend asked me about the bridge piers that are right next to the old Phil.& Reading bridge. There is quite a history on this and was called the South Pennsylvania Railroad. It was never built but a good bit of the grading and at one point the tunnels were used and still in use by the Pennsylvania Turnpike. I thought some of you might not have know the history and may be interested as it relates to some railroads folks are into.
Below are pics taken this past week while fishing there. The piers can be seen in front of the old Phil & Reading bridge.
Close up of the Philadelphia and Reading bridge.
Close up of the old CVRR bridge ( 3rd and final one on the same spot ). The first was a wooden covered bridge with the tracks on top and foot, horse traffic below. The second was an all steel deck truss after the first bridge burned. The third was as you see it below and built at the turn of the 19th century. If any of you remember the Utility model I built it worked this bridge back in the day in the hood.
Just don’t take a cat nap in the warm sun next to Enola yard as your buddy does have a camera!
