There are some changes / improvements in the Revolution Train Engineer equipment.
I’ll be adding these bits of information as I go, but thought I’d share it here until all the web sites and dealer sites get updated.
I’ve posted the pictures of the new PWC/PWM super receiver, and the new Linear one
The current capability on the PWC unit is 15 amps, and 10 amps on the linear unit.
At max current, a fan is recommended. I believe they will come with a fan.
Notice there is a housing when they were just naked boards before.
You will also note that there is no external fuse, it is now internal, and the overcurrent circuitry has been beefed up, so the external fuse is not needed.
The inputs are polarity sensitive as before, and never connect power to the outputs.
The 50791 PWC to Linear converter has also been updated to 3 terminals, but for now you also only use the outer 2 terminals on the input. I’m not sure if the 2 to 3 terminal change happened just now or a while ago.
Hope this helps.
