I posted a 3D printed adapter for the USAT GP9 last spring, but didn’t yet have a printer of my own. Some others (particularly Dan G.) adapted it for some other engines. I don’t know if anyone else has made use of them, but the ones on my GP9 have worked really well.
I have come up with a couple of new ones to share. Here they are:
On the left is a spacer for a 906 draft gear box on the USAT/LGB box cars/reefers with the link & pin pocket. Modification of the car and box is required, but it takes care of the height. Here’s one (black in the photo) installed:
The upper right is an adapter for the 831 gearbox for the rear of the USAT F7. The screw hole on the flange lines up with an original coupler mount screw hole. Then I bolt the gearbox all the way through the floor of the loco. Finally, a self-tapping screw goes at the coupler end of the gearbox. This requires drilling the existing hole all the way through the cover. The reason that the mount is asymmetrical is that I’m using a servo mounted inside the engine with the horn sticking through the floor (not pictured below, but see my previous F3 build thread) to actuate the coupler. Here’s one in place (dry fit):
Finally, the little thing is a replica of the lever that actuates the Kadee remote couplers. It clamps around the “brake hose”. With this, I can use my own servo and actuate any Kadee without spending $40 for their remote coupler.
