Earlier, I bought an RS-3 and equipped it with Kadee couplers so I could run on other layouts, such as Andy’s and Fred’s. It worked out very well at Fred’s for the standard gauge operation session. But, I still wanted something to run when it was time for Narrow Gauge! :o Taking an idea from Ric Golding, I decided to make my couplers removable and interchangeable. I have the AMS/Accucraft couplers and went ahead and bought some #1 Kadee couplers (1901). (A set of G couplers is also on order.) I first took some brass tubing and nested them inside each other until I filled the hole in each coupler. I glued these in place with JB Weld. On the AMS couplers I put some washers on each side; the Kadee just has a piece of brass on the top. All are now covered with Neolube.
To attach the couplers, I used the coupler pocket that comes with the Shay, but I mounted it a bit lower; I also added a 1/2" square timber below the existing two plastic timbers. I fashioned a “pin” to hold the couplers in place - it slips through the existing holes in the coupler pocket. A chain was added to make sure it stays with the Shay.
The pocket is positioned for the correct coupler height for the AMS couplers, which have a washer on the bottom to bring them to match my custom coupler gauge (24" in 1:20). The Kadee couplers do not have a washer and end up matching the Kadee gauge. The AMS coupler:
The Kadee coupler:
When I get the larger Kadee couplers I will mount them in a similar fashion. This should give me the capability to operate on the NG sessions on Fred’s layout, and I should also be able to run on Ken’s. The AMS will work just fine on my own layout as well as Bob’s.
