Anyone who uses direct burial, copper feed wires to power trains, lights, or whatever in the outdoor environment knows that regardless of how well you try to seal the wire, it oxidizes and corrodes within its insulation in the damp environment. The oxidation forms a dark/black film on the strands that will not take solder.
In the past, I would used sand paper or an X-acto on the wire to scrape off the film enough to get the wire to take solder.
I am now redoing my ground signals, changing the wooden stantions to concrete, and many of the wires going to the LEDs had corroded apart from their direct burial Malibu feed wires. All of the wires (even those still connected to the Malibu wire) had the oxidation film.
This wire to teh LEDs is small gauge and sanding it for soldering would probably remove most of the strands. The connections at the LEDs were still good, and I really didn’t want to replace the wires and deal with those again.
Having had such good luck cleaning the brass track with vinegar, Linda suggested that I try it on these wires. I put some vinegar on a paper towel and wiped the strands. This did a bit to remove the oxidation, but not enough.
So I stripped back some insulation and soaked the ends of the wires in a small cup of vinegar for two days. When I pulled it out, the copper was bright and shiny and the wire took solder like it was brand new. ![]()
