I just Googled “Solar Powered toys”…
You can get solar powered worms and cockroaches here:
http://www.electronickits.com/robot/robot.htm?gclid=CPr71qK1h64CFQWFQAod8X9T6A
http://www.dhgate.com/wholesale/solar+powered+toys.html
Regrettably, Jon’s comments may be very valid indeed.
On http://www.electronickits.com/robot/owi608.htm
I ran across this description of a solar battery:
OWI Solar Battery
The Solar Battery is comprised of a number of photo voltaic cells. Each cell is made from a slab of semiconductor crystal. When light shines on the cell voltage is produced that can create an electrical current in a circuit. The greater the light intensity on the solar battery the greater is the current it can produce. Solar Battery is compatible with OWI 6567 and OWI 6577 kits and many other solar experiments. Intended for use to familiarize students and/or hobbyists with functional solar cell principles, and practical applications of solar cells. Mounting bracket not included. Safe, simple-to-use encapsulated mini-panel. Sturdy panel will endure handling without the breakage and cell damage traditionally associated with solar cells. Create various experiments by exposing and positioning the panel to the energy source. This powerful solar battery features 3 cells in a sleek, low-profile protective housing with mounting holes. Positive and negative terminals are indicated to take the guesswork out of installation. Lead wires are included.
Current: 350mA. Voltage: 1.4
Compatible with models: OWI-6567, OWI-6577
Dimensions: 5" x 2.5"
Note: This is a completed product, no assembly required. OWI608 - Solar Battery - $17.95
350mA may be too little, especially @17.95 !!!
I wonder if that would turn a small motor and drive my waterwheel - I suspect that a simple turning waterwheel would require relatively little power, while a pump with its reciprocating action might be a different matter…
I guess I would be prepared if necessary to start my waterwheel with a little push…
But $17.95 … wow, that’s steep for so little power, isn’t it!!
I’m thinking maybe I should forget solar and just use a wall wart after all. But I’ll keep thinking about solar for this future project, maybe do some more research on all this.
You’ve set me thinking, Mik.
