I ordered a battery powered smoke generator for something other than G-scale. It got here today, and after seeing it, I thought about how I could use it in my dragon bus, which currently has a track powered Harbor Models generator. The generator is a Costronica Pocket Smoke, which is based off vape technology. It uses propylene glycol for smoke fluid, instead of mineral oil. It was fairly inexpensive, though a longish wait, since it came from Belgium, I think. I was able to remove the Harbor models unit, and hook the newq unit directly to the already in place tubing. The smoke tends to go down, instead of up. Not sure if I like that or not. What do you think?
