Can Lionel smoke fluid be used in a big hauler? If not what can be? Thanks Denny
Dennis Blockburger said:Just so long as you keep it downwind from me ;)
You must be an american flyer guy!
Years ago, the SoCalif. Garden RR group did a “study” on smoke fluid and what-works-with-what per locomotives. Those participating found:
- Smoking quantity differences with LGB/USA/Bachman/Aristo smoke units is independent of the fluid used;
- Genuine lamp fluid (genuine?), not a “lamp oil”, works as good as LGB’s fluid, and the others.
- Whatever the choice, don’t overfill. The LGB (Suethe brand) works best when 1/2to 3/4 full.
Wendell
I used to like the Dept 56 Magic Smoke. They discontinued it and my bottle has gone dry
Smoke?
What’s that?
Oh, you mean that wispy, wanna-be, can’t hardly see stuff coming out of a locomotive’s stack?
Now if you can give me lots of black, billowing smoke, I’ll re-hook up my smoke generators.
Isn’t smoking bad for your health?
When saying lamp fluid, do I try my kerosene?
Doug-
You likely have experimented with lamp fluid vs. kerosene already. If so, please let us know if the smoker system heat will ignite either the kerosene and/or lamp fluid you purchased.
The labeling of lamp oil, kerosene, tiki torch fluid, etc., may all have the same application in the manufacturer’s thinking. I buy those fluids that illustrate on the label or state in writing an application for wick-type lamps. A tiki torch fluid appears to be the same as the “lamp oil” I have purchased. I have not had any of the fluids I’ve experimented with go from smoke to flame when used in either LGB/Aristo/Bachmann smoke units.
There is always a first time.
Please let us know what you have discovered – and the brand names.
Thanks,
Wendell
Hmmm. Lamp oil?? Enlighten me please… flamables scare me.
I bought all the dept56 smoke fliud I could when a local store was closing, still have a few bottles.
When thats gone in a few years I’ll have to find a source for propolyne glycol and mix my own odors into it.
john
I’ve just always used Aristo fluid 'cause I have mostly Aristo trains. I didn’t use the smoke unit till a year or so ago.
Lewis Polk adds candle cents to his. His wife says they’re lovely.
Confusion? Understandable. “Lamp Oil” is the fluid used in kerosene (huh, now the word kerosene?) cloth-wick lamps – the ones brakemen used and seen on T.V. “B” western movies hanging above log cabin poker tables. K-Mart had it with their wick lamps. I found the lamp oil works great in loco smokers. The “tiki torch” fluid may be the same – I don’t know. Home Depot has it in 1/2 gallons at $9.
Wendell
Wendell Hanks said:
Confusion? Understandable. "Lamp Oil" is the fluid used in kerosene (huh, now the word kerosene?) cloth-wick lamps -- the ones brakemen used and seen on T.V. "B" western movies hanging above log cabin poker tables. K-Mart had it with their wick lamps. I found the lamp oil works great in loco smokers.[b] The "tiki torch" fluid may be the same -- I don't know. [/b[Home Depot has it in 1/2 gallons at $9.Wendell
The Tiki lamp oil usually will keep 'skeeters away, too.
I actually have about six kerosene lamps in our 60-foot “log cabin.”
And I even have two Skater’s Lamps! My mother collected antiques.
Okay, I’ll bite. What’s a Skater’s Lamp?
We are toooooo young but they are actually small kerosene lamps that ice skaters on the lakes and rivers would use for ice skating at night.
One of the lamps I have has a green glass to cut down on the brightness of the light!
Lamp oil is more or less #1 kerosene.
Processed to remove odor, clarified and sometimes scented and colored.
If buying “canned” kerosene, I believe it is usually #1 kerosene.
At the pump, you may find lower grades.
Ralph-
Any thoughts on #1 kerosene, sans the clarifiying, creating smoke via the LGB/Aristo/USA/Bachmann “smoker” units?
Paying the $10+ for a small container of commercial “smoke fluid,” knowing it might simply be repackaged #1 kerosene with an odor additive, does not sit well.
Any brand names for “canned” kerosene? Where purchased?
Many thanks,
Wendell
Wendell,
I don’t know what they use in “smoke fluid”.
I can buy a gallon can of kerosene for around $6.00 at the local hardware.
Don’t remember a brand. I usually buy it at the pump at half the price for my lamps and tiki torches.
OK since all this knowledge is being passed around. Anyone know how to make the smoke black instead of white?
I like the smoke generators in the USA GP 38’s but I don’t like the white smoke as it’s not appropriate for diesels.
