Next I moved onto the side rods.
.jpg)
To make them I used a piece of brass strip 1/4 X 1/16, a piece of .250 X .125 brass tubing, .100 X .187 styrene strip, .060 hex rod.
.jpg)
Now each of the rod ends are made 1 cm long. But to make them it was easier to make one piece 5cm long and then cut them off. I did this by soldering two pieces of the brass strip to the small sides of the tubing. I did this for two reasons. The hole needed to go on the wheel would have been to large for just the tubing and also it gave a solid piece I could bevel. Once you have them soldered on then file everything down flush. You certainly could use a narrower strip and save on filing but this is what I had.
.jpg)
I then cut them of 1 cm long and then had to plug one end of each piece. I don’t know what size rod this is.
.jpg)
.jpg)
Then you file them down to a desirable width that leaves enough meat to drill the hole and also look good. then bevel the open side ends.
.jpg)
Then fit these on the styrene rod so that the length is where oyu need it, for me the crank pin center to center was 1 5/8 so I made my side rods 2" which place the wholes in a good spot.
.jpg)
.jpg)
I glued them on with CA. I also pushed the styrene in all the way so I could drill through it as well. I drilled the holes in four steps increasingly larger sizes to avoid the bit wanting to tear through.
Next make the con rod. To do this all I did was take the same square brass tubing without the side brass added, closed one end, shoved the styrene rod in and glued it and drilled the hole. The shoulder bolt I made is a smaller diameter so it was not necessary to reinforce it and I wanted a smaller profile. I measured its length by moving the front axle to the rear so it would rotate and then put the rod on and rotated the wheel to a position closest to the cylinder and cut it at a length that looks right.
.jpg)
.jpg)
And that’s the results.
