Tony: the cells I got are actually larger than AA cells. They are about 1/2 again the size of a AA battery but not as large as a C cell. I was unaware that the Lithium cells were larger so I purchased a couple 4 AA battery holders from my local electronics store. Well I found out pretty quick that I could not use them, so I just tossed them in my electronics parts stash box for some future use. Since the holders I had didn’t fit the batteries, I did a Google search and found that digikey had them along with a few other suppliers, but they wanted more for them and some had them prewired in parrellel for greater amperage output , but not for voltage. If you go to the digikey website they have the specs on the holder. I am assuming that they sould not have any issues with them as they are specifically designed for Lithium Ion Batterys.
The specs I read say that the contacts are made of 302 Stainless Steel Spring Temper, Nickel plated. Here is the link to teh specs. http://www.batteryholders.com/BK-18650-PC8.PDF .
To find out what the resistance the contacts are I guess that would be a question for the manufacturer which s Memory Protection Devices, Inc. Farmingdale, N.Y. http://www.memoryprotectiondevices.com/ They sell the holders under thier subsidurary company of http://www.batteryholders.com/show-part.php?part=BK-18650-PC8.
I found this in some of thier technical specs on the Batteryholders.com website under contacts.
Lithium Battery Holders
Features:
Easy battery changes without any tools or soldering
Light weight with high strength
30 years of worldwide sales in many diverse applications with documented performance
Exceeds requirements of ANSI/EIA-540J0000
Contacts:
Bright nickel plating over stainless steel base metal
Excellent in backup applications or low current applications
Industry standard pc pin spacing
Outstanding resistance to corrosion
Low resistance, under 50 m¥Ø
Plastic:
PBT*, excellent chemical and solvent resistance
Broad service temperature range with excellent thermal cycling performance
Excellent toughness and strength
Dielectric strength 560 volts/mil at 25¡Æc for 5 sec.
Insulator resistance: 5000 M§Ù minimum
I hope this answer your questions.
In any case I have them on order. Got the charge / Discharge monitor boards today, so just waiting on the holders now.
Dan S.
Denver & Rio Grande Southern
