Once I was through with my inner/outer loop connections I thought I could take a siding I had and add to it, by the time I got done I had a small yard. The inner line is intended as a passing siding and I’ll get track power to it with the switch you see, it’s on the short line right now but I aim to change that. I still need to level it all out, but the grandkids are due in soon.
From the side, I will make a control tower also, later on.
