I have an electric Aristo Craft 0-4-0 with sound and puffing smoke that I use on my switching problem. It is track powered using an Aristo Craft TE with the Aristo 10 amp power supply designed to plug into the TE. I run the engine on full wave DC, not the PWC option. The engine is very smooth and runs at a comfortable switching speed at a voltage less than the sound and smoke need to begin to work. According to the Aristo Craft instructions, the sound and smoke need 6 volts to operate and at 6 volts on the track the engine runs to fast. Even on PWC the engine runs to fast before the smoke unit starts to work. Is it possible to put a resistor in one of the motor leads that will allow the sound and smoke to come on before the engine starts to move? I know resistors can get hot. I am worried that a resistor large enough to perform this way would get so hot that it would damage the plastic engine. I also need to know what size resistor I would need to obtain. I haven’t opened the engine up yet to even see if I have room to do this. Perhaps the heat problem could be solved by hanging the resistor in the the open air in the cab, not close to anything that would melt. The engine is only used as a switcher, so top end speed is unimportant. If y’all feel this isn’t practical, just say so. Any help and opinions will be greatly appreciated.
Oldpartsmaker
