LGB (yellow) versus Accuraft (red) passenger car
Dang! that .02 makes a huge-mongus difference!
thanks for the photo!
C. Nelson said:You mean 2.2? [20.3 to 22.5]
Dang! that .02 makes a huge-mongus difference! thanks for the photo!
tac
Terry A de C Foley said:C. Nelson said:You mean 2.2? [20.3 to 22.5]
Dang! that .02 makes a huge-mongus difference! thanks for the photo!tac
www.ovgrs.org
cale
It’s not the size, it’s how you use it…
…and I could use some of those LGB-size cars on my layout.
Ray Dunakin said:
It's not the size, it's how you use it... ;)…and I could use some of those LGB-size cars on my layout.
You’d have to colour half of them in to suit you tho’, right now they are dark green.
Besp
tac
C. Nelson said:Terry A de C Foley said:C. Nelson said:You mean 2.2? [20.3 to 22.5]
www.ovgrs.org
yessir…you are correct! see why I added that sig line!cale
Besp
tac
I’ve kindly asked the Maker to allow me a 24-36 mo. reprieve!
Gary Armitstead said:Gary, Indeed! Small is beautiful!! Best wishes from Tokyo, Zubi
The size difference is awesome!
The more 1:20.3 stuff I aquire, the more pissed I get at LGB for their “not-to-scale”.
But, there wasn’t anything else back then.
John Bouck said:John, it is a bit like comparing apples and oranges, indeed both grow on trees... The main concepts around which LGB trains were built are 1) playability 2) cuteness 3) robustness. Using these concepts LGB gave the customers a possibility to run trains which would not only never meet in real life, but would also never be able to run together. On the other hand, the concepts recently favoured by other makers and some modellers are 1) accuracy 2) detail. These are simply nearly mutually exclusive approaches! Nevertheless, there is still more "to scale" LGB than I can afford, and unless LGB gets in trouble again, they may also release some full length US coaches as prototyped for the "old LGB" by Barry Bogs - only time will tell. Best wishes from Tokyo, Zubi
The more 1:20.3 stuff I aquire, the more pissed I get at LGB for their "not-to-scale". :) :) But, there wasn't anything else back then.
