I had a big spill in my Connie build and I’m trying to figure out how to proceed with the “fix”
Here is the picture:
When my Connie took a tumble from my work bench it landed on the corner of the smokebox. As you can see in the photo, it crimpled the thin embossed styrene. I was thinking if I used some glue and simulate a welded seem over the cracks it could look like repaired damage from a previous wreck. I’m modeling early 1920’s so I don’t know if they used to weld stuff at that time.
I would rather not take off the glued on styrene sheet because I would have to start over, but it is an option.
What do you think???
