In my Challenge 2013 posting there were some shots of a simple jig that I use for clamping together the frames of the cars that build. As all my cars follow the same basic design I made this jig some time ago to help make sure that the frames are straight and square. This is the basic layout. It is a piece of 5/8" birch plywood with a straight edge attached to one side and a short edge on the end.
It is very important that this corner is absolutely square.
The clamping block is a piece of 1/2" birch plywood with a slot cut on appoximately the center line. Again it is important that this corner is absolutely square
And that when the clamping block is tight against the rear straight edge that this angle is also square.
I installed two blind nuts for the fixture clamp to thread into. They are ressessed into the bottom so that the whole jig sits flat on the table top.
This is what it looks like ready for use. Overall it is 24" long by 7" wide. I can clamp a car between 12 and 19 inches long. It can be used for cars up to 6" wide but most of mine are only 4 1/4".
When glueing up a frame I put wax paper between the frame and the jig to keep it from sticking. I use Titebond 3 or Gorilla white glue as it gives more working time to get everything tight and straight.
Only thing is be sure that all your stringers are exactly the same length. There you have it. An easy way to make sure that your frames are straight. Ron
