Its still there in my profile but its not showing on posts.
Is there something I missed to get it back?
Vic,
It seems as if profile is stored in at least two places, but is only read from one.
Note at the very top of the screen, you will see an area that contains the links: UPDATES MY PROFILE MESSAGES SETTINGS
If you go click on MY PROFILE and then “Edit My Profile”, you will be working with your OLD profile. I found this handy to see what my old one was.
To update the signature that the current system is using, select “SETTINGS” instead. There you will see another set of links - one of which is “Forum Signature” That’s the one to select and work with. You can easily insert a picture or whatever you want to show in your signature.
Cool. If you’re at the “Forum” level (that is you have chosen a particular forum, such as Website or Rolling Stock), you might notice a link “User Dashboard”.
If you click on this, it will allow you to modify your signature there. You can also monitor any watched topics.
Thanks guys that did it
Well, at least you didn’t panic.
