Here is a new thread, to separate the stuff we are doing here on the IPP&W Railroad, from Bob’s original thread for his railroad.
I will post pictures here as soon as I get some…and welcome any comments or thoughts on the subject here.
The original plan I had was a simple signal system, controlled by the dispatcher, to protect the crossing of the IPP&W railroad, where it is crossed by the RP&M railroad. Just a simple system with four red/green signals, one located at each approach to the crossing.
The signal lights would be LED’s to provide a low cost, long lasting light in each head. The lights had to be bright enough to be seen by the operating crews in broad daylight, at a distance of 15 feet minimum.
The lights do not have to be scale, or delicate, in design, but should look “Railroady”, and be very durable, to be left out year around through all types of weather in a temperature range of -30 to +30 C.
The lights, are to be used as part of the operation control system, during operations, but at night and other times, act as “Garden lights”, drawing low amounts of power.
Along with the signal system, power can also be supplied in limited areas of the railroad, for station lights, and other industrial lighting, which would be generally considered “Garden lighting”. Since the power cables are in conduit, and extra cable has been drawn through it, why not use it for lighting buildings…
Some would ask…why not use the track as a power source… We don’t use track power, and so it would be more work to keep every joint “Conducting”, and the risk of shorting the rails, would be more work than simply running a length of free conduit, with free cables inside it…I am fortunate to have good sources…!!
Fred Mills.
