I have desided to enter the door challenge, I have been contiplating on a water tank, since most of my GRR is operated on a shortline shoestring budget. So most of my structures are to resemble OLD, BROKEN DOWN, WEATHERED. I draw everything in sketchup, this gives me the look and design I am after.
Since I cut alot of my building parts in a laser machine, I need the parts in CAD so I can cut in the laser.
I have chosen to build this structure out of acrylic instead of steel, My structures set outside ALL the time, so I really focus on designing my structures to withstand the large difference in our SW Missouri elements.
My structures corners all use a type of box joint construction, I fine tune the fit to a perfect fit, not real tight, but tight enough to hold together without clamping, with just enough room for glue for good bonding.
Walls all seperated ready to go into the program that operates the laser machine
The door has been ran through the bandsaw to make thinner
