I’ve been toying with the idea of finally unboxing all my rolling stock and building shelving specificly for storing rolling stock. The idea is to ease using the equipment, and to allow me to either dispose of or store elsewhere all thier enourmous boxes. Well, this weekend, er Friday (since my weekend is Fr-Sa), I did some quick mesurement’s and headed off to the local hardware megastore. Got all my lumber (and some extra PT 2x4’s for the outdoor work of course!) and began teardown of the old shelving the previous homeowner built. I managed to get one side completed today, and work started on the other half of the shelves. Of course I wasted no time in setting up all the cars I’d shoved outside to clear the staging yard for the days work. And here’s how it all turned out:
As you can see in this picture, the bottom shelf isn’t as wide as the upper shelves. One reason is HD didn’t understand what cut a sheet of plywood in half means, I ended up with a 4’x4’ 2" and a 4’x3’ 10". The other reason is I figure making the lower shelf 6" shorter will ease viewing and adding/removing cars from the tracks’ below.
