Last Tuesday night the JRVP and I were operating Shay no 117 in the newly falling snow. Everything went well it worked fine, I might add this was its first run on rails since the new EVO 3 and Sierra sound install took place. We ran for prolly 45 minutes before we got cold we pulled the Shay into the old shop building (unheated, but under cover) and removed the batteries and took them and the transmitter inside. The next day I fire the loco up and pulled her out of the shed and then I lost power to the motors, both trucks…lights, sound, and RC are still working but no power to the motors. I brought it inside and cracked her open, the connections seem to look ok but still no power to the motors.
Today I suspected there might be a jam in the gears of some sort, so I took the covers off and inspected, all seemd normal, WOW! I got power to the motors! Then after a about 45 sec the trucks slowed and now once again I have no power to the trucks. In removeing the electronics from the tender I did pop one wire loose that caused the sound to quit , but was too tired to get out the diagram to figger out where it goes back (single black wire from the accessory board to the EVO Tony I think!) Could this be part of the problem? the trucks started working after I had rolled her on her side to get the bottoms off the trucks and then quit when I put them back on and rolled her back on her wheels… Any ideas where I might further birddog to isolate this problem?
