The mountain community of Hyampom needs some business buildings.
Humboldt Fir has a large plywood plant at the edge of town and is the major employer in the area, however there are several small lumber mills and gyppo loggers in the valley not to mention the ranches and a few scattered mines that keep the small business district in town quite busy.
This is the area that the town will occupy. The Humboldt Fir office is the small building on the left and the town will run about 16 feet up to the area of the switch in the distance. The location is along the boundry fence, as you can see, so everything has to be flats or 3-D flats.
The first âblockâ of buildings will be about six and a half feet long. The buildings will be held together as a unit by this base box made from OSB siding and painted inside and out with old left over paint. The box also has screened vents for air circulation. This box will bolt to the 2 X 3 runner along the back of the bench work and make a solid base for the flats and be completely unseen when finished.
Here the first three buildings are sitting on the base box in various stages of completion. The large brick building on the right end is made from Sintra as is the white one on the other end. The small building between them is of wood construction. The grey area along the bottom of the buildings hangs below the base box and will go down into the gravel/soil on the table top. As with the other 3-D flats I have done they will be completely enclosed and with screened vents to keep the Paper Wasps and Mud Dobbers the hell out of them.
Three of the buildings are pretty much complete, they are/will be starting from the right end; The Grubstake Diner, the Hyampom Hotel, Fast Eddies Card Room, and Maggies place. The last space at this point I think will be a feed/hardware store but that isnât final at this point. They arenât fancy but remember these are the back alley side of the buildings facing the railroad tracks, fancy was saved for the paying customers around in front(https://www.largescalecentral.com/externals/tinymce/plugins/emoticons/img/smiley-smile.gif).
Thanks for taking a look, more later.
Rick
