Jack’s been busy replacing all the track that Irma ate, and it is now in good shape. I took the little gons and flats over for a run whiled he replaced the shade cloth on the trellis.
My boxcab decided not to work (another broken wire) so I borrowed the LGB 0-4-0 to test the outer loop and then pull my gondolas and flats. (The flays will be converted to hoppers in a few weeks, hopefully.) That loco is big - I’d say more like 1:19th scale than 1:22.5 ? The field railway cars are similarly large. Fine with me.
This is the bridge over the waterfall (between the hot tub and the pool.)
-lgb2063-gons-flats-van-waterfall-10.jpg)
Then out came Otto, one of my vertical boiler live steamers. He did the usual stalwart job until the water ran out. The flats were put away and I ran with just the gons. Both driver and brakeman are 1:19th scale (Bachmann Europe.)
