My model of Rio Grande Stockcar #7403 won the Second place in the Freight car Modeling contest at the National Narrow Gauge Convention this past week, and i thougth i would share some photo’s with you. As displayed
From the “A” end
From the “B” end
from the underside
Truck Detail
Brake Cylinder detail
Model is completly scratch built. only comercial parts ar Bob Hartfords Bettendorf Truck side frames and detail kit, and brake clevises, and various mfg’s NBW castings. the brake cylinder is a new casting of the correct size cylinder, the wheel centerswere spin cast, tires and axles were turned on my lathe. all the new castings were designed in 3d in a program called Solidworks and the files used to create Rapid prototype masters. the base carbody was laser cut from my own 2d autocad files. the photo etched components were made using Micro Marks Pro Etch. also note the cotter pins in the brake rigging. Enjoy
