Now We need to build the tail section of the winter hatch.
Take one of your roof fans and cut off the electrical conduits. We are going to mount this fan sideways to make sure it clears the winter hatch. The hatch will hide this when complete.
Now take some 1/8 x 1/4" styrene and cut one 1 7/8" piece and two 2 7/16" pieces. Glue these together as shown below. The narrow 1/8" side is up.
Now I’ve decided I don’t want this hatch permanently attached as it will make painting difficult, and would also make it impossible to get at the fan. We’re going to get a little fancy, and pin this to the roof so that it will be removable. We’ll pin using 3/64" brass rod. Using a 3/64" bit, drill the corners, and from the corners, drill at 1" and 2" from the corners. The open end is the front.
On the .01" roof plate, draw a line 1/16" in from each side.Place this frame on your roof. The frame will sit between these lines. Line it up, flush with the front, and mark and drill the holes through the roof.
Once the holes are drilled in the roof, Take a 1/16" bit and widen the tops of the holes. This will help guide the pins into place when you mount the winter hatch on the roof.
Cut six 1/2" pieces of 3/64" brass rod and insert your pins. Make sure you flush them with the top of the frame. I scarred the top 1/4" with a knife so that they would anchor to the frame. Make sure the portion going through the roof is smooth. Carefully remove the frame from the roof. If the pins moved at all, flush them back up. Apply some solvent and the pins should remain nicely attached to this frame.
While the frame is still attached to the roof, mark lines on the inside front edges of where the frame meets the roof. We are going to mount a small plate in the next step that will help the tail tie in to the middle section.
