My old reliable Bearcat BC120XLT scanner battery has died and won’t take a charge. I went up to Amazon to get a replacement for the:
BP-120 Nickel Cadmium, DC 4.8V, 600mAh ( data from original battery)
The Question is. I find 1200mAh NiCd sets which would give me about twice the run time. Would the unit handle the added size to charge properly? And would there be any issues with the built in charging, other then it would take a longer time to get back up to full power?
I also find 2200mAh Ni-MH units. Question is would this battery work and or charge in the unit, without damaging the built in charger? I like the thought of nearly 4 times the run time. Could I swap the NI-Cd for the NI-MH without issues?
Thoughts and opinions?
