I have been running our Pre-Owned ST under the tree a few hours at a time per day…I have lubed the valve gear-exposed points…is there any internal lube that needs to be performed…if so-how?
thanks and Merry Christmas
cale
cale
Yes.
The axle bearings, motor shafts, and gears.
Might have to drop the bottom cover to access.
TOC
Merry Christmas to you too …
She running ok?
Matthew (OV)
Matthew (OV) said:
Merry Christmas to you too ...She running ok?
Matthew (OV)
cale
Good, good. Here she never got much beyond a test run or two … though at one point doubling with an 0-4-0 sidetank (most recent edition before the one that’s coming out now) she pulled a 15 or so car train …
And … the diesel looks good here too!
Best,
Matt
Howabout lube’n with “Labelle 106 Plastic Compatible Grease with PTFE”
it’s what the LSH had in stock and recommended.
Merry Christmas
Cale
works fer me.
