Well, it is time to put my lava rocks and dirt to use before the latter washes away into the yard!
Oldest Daughter and I did some of that today turning this:
Into this:
If I may brag, she did the rock fitting. I was just the muscle.
We have some finishing work to do in this area, which gives me time to ponder the next project, connecting our two mountains with a lower saddle. Like this project, I need some “mass” to make the tunnel complex look less spindly. When the impatiens come in, this serves a the required visual block. I wanted to do something a bit bigger to make the mountains as whole look like part of bigger range.
I have to recycle and older photo to give a sense of the space, please forgive me. Roughly, the saddle has to connect the tunnel masked by the avocado tree (the Dudestep Range) with the mountain on the right (Hell’s Mountain). You can see our tram pulling a long string of minis in that area:
Primary viewing angles for the Triple O are the lanai, off stage left, and the grill area, off stage right (Find the B’mann 4-6-0 and follow it to the caboose.). Folks usually go from the lanai to the grill, where we set up a fly, then follow the track around behind Hell’s Mountain where we have our rosemary forest. This gives a not so impressive view of the Dudestep’s spindly construction. It probably only bothers me, but still…
The plan is to use half hollow tile along the backwall, then shape the front with lava rock. The issue is the tunnel itself. I am thinking about using the same technique I used for the Dudestep, namely half hollow tile topped with concrete paving stones then stacked liberally with lava rock and broken concrete, but I want to avoid that spindliness. Space is also an issue, and I am even wondering if this will work. The one option I am weighing is using some sort of plastic material, like decking, creating a false front, scoring it to make it look like a wooden portal, and fixing that to the tunnel supports. Since the back wall is the garden’s backwall, I don’t think it’ll make it too boxy, but I welcome your opinions.
For the life of me, I cannot find the actual planning photos I took, but, for fun, and to give a sense of the space constrictions, I offer the challenge…Make a tunnel that can hold Fort Union and allow 1st Section, Battery B, 2nd US Artillery to drill in safety:
I’ll have some better planning photos up later this week.
Start date for this project is probably Labor Day Weekend.
Thanks as always for your help, and have a great week!
