Hey all, Well, Another of life’s unexpected turns is causing me to shelf this project for a few months. Any of you who followed along in my layout build log know that it was on and off due to the prospect of moving. As luck would have it one of my job prospecting irons finally heated up. Yesterday I accepted a job offer from Brookville Equipment Co. (http://www.largescalecentral.com/externals/tinymce/plugins/emoticons/img/smiley-sealed.gif)This is a fantastic opertunity with a great company but it will require us to move to the Brookville area in pretty short order. Again, I’m not complaining at all because I am thrilled that we are going to be living just below the Allegheny National forest in such beautiful country. It does however mean a full stop on all hobby time in order to prepare and start packing. In fact I will be going out after this post to number the track pieces and dismantle the layout today before it gets buried in snow and frozen to the ground. Just goes to show you never know whats coming or when!
I feel bad for generating all this interest, especially in the lighting system and don’t want to leave anyone hanging. For that reason I have created the rough sketch below to show how I will be tackling the installation on my loco. Basically I will bend the Led leads in the Z fashion shown so the light points the appropriate direction the in the headlamp casting. An issue arises when the bare leads have to pass through two brass parts which would short things out. I’m going to solve this through the use of two (the top might be two shims or one with a split or holes in it) thin plastic shims sandwiched in between the brass. To get the power back to the cab and on the the tender. I will pass the thin magnet wire for the positive lead through some 1/16 tube. The negative lead will be soldered to the tube which will double as the conductor in to the cab were another wire will be soldered to it to take the negative side of the circuit into the tender.
I’ll admit I was a bit concerned about all this need for a resistor in a LED circuit too. But with a bit of Googling all questions were answered. Just type in “LED resistance calculator” and you get a number of results like this one: calculator to do the math for you. Just enter the battery voltage, the led voltage and the LED current and it will tell you exactly how many Ohms of resistance your Resistor should have. I went to Radio Shack found the LED I wanted, then used my phone right in the store to run the calculation. Then garbed the right resistor out of the drawer all in a few moments time. As I said earlier, I tested it when I got home and it works perfect.
Well, this thread will go back into hibernation for a few months, but fear not it will return. I really want to finish this thing, it’s so close!
