In addition to installing a Revo receiver and Phoenix sound board, I’m also converting my Aristocraft 1/29th scale RS-3 into a freelanced 1/24th scale narrow gauge loco. For now I’m holding off on the electronics until I get the other modifications finished. I started by widening the deck. To do this, I glued 1/4" square styrene strips to the edge of the frame, then topped them with 1/4" x .010" strips. I still need to cover the expanded deck with new non-skid treadplate:
Next I made the hoods slightly taller, by gluing 1/8" x 1/4" strips all along the base of the hood pieces. I also reduced the length of the short hood, in order to accommodate a larger cab:
I also removed the “bug-eye” classification lamps. Soon I will remove the existing grab irons, fill the holes, and replace them with new grab irons that will be larger and spaced more appropriately for the increased scale. To make this look like a narrow gauge loco in 1/24th scale, it needs a new, bigger cab. I began scratch-building one out of .080" thick styrene. I cut the front and rear walls to shape, taped them together and carved out the windows. While doing the windows I also trimmed the curved edge a little more:
Here’s how it will look on the loco:
That’s all for now. I’ll post more updates as I go.
