Last spring I picked up a Roundhouse Sammie with the intention of modifying it into a logging engine. I was not sure exactly what I was looking for. I recently joined the 16mm association and while browsing through the Aug 2013 issue I came across a really neat modified Sammie. It was done by John Fox in the UK. As soon as I saw it I knew that’s what I wanted. The picture did not show the back of the engine so it was hard to tell if trucks were added to the rear. At the time I happened to be exchanging e-mails with Chris Bird of Summerlands Chuffers. I was telling him about the Sammie I saw in 16mm today. Lucky for me Chris had some connections and was able to get me connected with John Fox. I was able to get more photos and a description of what was done. The below photo is what I plan to convert mine into. I have to give John all the credit for how I am going to do this. Thanks to Eric Shade for the rear trucks.
Parts that I have gathered so far.
The first step will be to take out the foot plate and add a longer one to the back. The best part is the metal cab is soldered to the saddle tank. Johns way around that was to fit a wooden cab over the metal one. Then the saddle tank does not have to be disconnected from the cab. By leaving the metal cab adds support to the wooden one.
