Good run with the rotary on it’s first outing, even with a low battery(goofed up there!) It spins the blade, engines are track powered. I lef them out overnite in the tunnel under the waterfall. Just had to put in the battery. Flanger between the trucks was working good also. More snow is forecast for tonight, so left them in the tunnel again. http://www.youtube.com/watch?v=ewugstqn6LU Still pix: This first one I just pulled it out of the tunnel, did use the board to scrape the snow a bit.
Rest of the pix were taken after the first run, look at the video to see the action.
