Hi Everyone,
Long time lurker here as well as a returning enthusiast to the large scale hobby. I have been into trains since a child, starting with an HO layout and then finally convincing my parents to let me build a garden layout in our backyard as a teenager.
Put the hobby on hold for a bit through college, getting married, having kids and buying a house of my own, so now I am ready to introduce my children to my favorite hobby.
Had a question/looking for advice on roadbed and ballast. For my first garden layout, we used that insulation Styrofoam board ¾” thick from HD, cut it into 4 foot strips x 4” wide, painted it brown and then secured it to packed, leveled dirt using 4 inch nails. Then put small finish nails through the ties into the Styrofoam and ballasted around everything. This seemed to work pretty good, didn’t have the rot issues of wood, you could stand on the rails if needed and you didn’t crush the Styrofoam and you could shim (i.e. push dirt/rock under the roadbed to re-level the track. Being in Southern CA, we don’t have the frost/weather issues and it survived the heat and rain pretty well.
It was a bit of an un-conventional way to do it, but it worked pretty well. The only problem is that it was quite a bit of work, and mess, cutting, pulling the plastic coating off the Styrofoam (we found out latex paint will not stick to the covering and just flake off, so that lead to re-doing ¾ of the layout a year later….) and the ballast didn’t seem to stick very well around it (this could have been a ballasting issue too)
This go around, I was thinking concrete roadbed, but not sure. Also was looking at doing the floating style by digging a trench and doing the rock base and ballasting, maybe pressure treated wood…
This layout will be much smaller, about 10 x 20. We are still in Southern CA, so temperature extremes and weather other than rain (or lack thereof) are not a problem. Will probably do a continuous run modified over and under, or just a slight rise in grade then back down.
Looking for some advice on ballast grit this time around too, and any vendors in the So Cal area if anyone can recommend one to get ballast. Open to any and all suggestions as this will hopefully be a long term install as we don’t plan on moving
Thanks,
Chris
For painting, I usually went to HD and found a gallon of oopse paint and asked the guys at the paint desk to add in a bunch of colors to make it a dirt colored brown. Tops and bottoms were pretty easy with a roller, but the sides…unless you had a super sharp knife or something that left you clean edges, painting the rough edges of Styrofoam was trying. Maybe a paint sprayer would have been easier, but hey, I used what I had and what was low cost, elbow grease and a paint brush!
