I just yesterday received from RLD my new track bender. I do not belong to any club or know many who are so I didnt even think about borrowing one, so after a little research ( checking prices) and looking at different brands I got one from RLD. When all you have to go by is pictures it is hard to understand what it will be until it shows up.
First I must say it came quickly and well wrapped, picking it up is a struggle as it weighs a ton. Sturdy construction and well built, nice rounded corners. I grabbed several lengths of flex 332 brass track and plopped the bender on and made a few passes, tightening the adjustment wheel with every 2 passes and at first I thought it was not doing much but after about 4 passes I easily had a 6ft long 10ft curve. the bearings and the plastic that the rails ride on make it glide effortlessly. bent one half way took the bender and turned it and bent the other half the oppisite direction for a nice smooth s curve. then un bent the curves I made, just to see the difference.I worked one piece of track down to a way tigher curve than I will ever use and it did it all with ease.
One little problem I noticed was if the rails are connected the bearings hit the joiners. I am going to see if putting a small spacer under the sliders will help, but for now I just wanted to try to see how it worked.
I must say when I first looked at RLD it was out of stock, so I emailed and asked if they would be in stock, I got a prompt email back, gave my name and he put ne on a list to be notified when they came in. Quick and personal service from Robby, I will use his services again.
