I needed some 4 x 8 sheets of plywood cut in to equal 29 1/2" x 47 15/16 " panels. To me this was a daunting task because of dealing with the size of board. It is very difficult to control a 4 x 8 sheet and keep it level on the table of the saw. So I use a circular saw with a fence instead of a table saw and hope for the best cuts.
I usually buy plywood locally and have it delivered, but it is still a lot to handle single handed.
Have you seen the big rack saws at Home Depot? They sit in the lumber department and the plywood is stood up in the saw and the cuts are easily handled, both horizontally and vertically.
I choose a non-busy time to visit HD and asked if they could rip 2 pieces of plywood to the dimensions I mentioned above. No problem. I was more than willing to pay for the cuts, but since the guy wasn’t busy there was no charge.
So now the 4 x 8 sheets of plywood were reduced to 4 panels that were much easier to handle, precisely cut and loaded into the van by myself, along with the cutoffs that will be ripped on the home table saw in a much more controlled size.
Now, very few ideas are original. Thank God that I have friends that can help me through the tough projects. I don’t know where this was jogged into my little bit of grey matter, but to whoever brought this forth, I am forever grateful.
I am currently rebuilding the benchwork of the “Timesaver”, that is a completely different subject and one that I will exhaust you with the details of later, but this is what the plywood is for.
I don’t know if I will ever man-handle a 4 x 8 sheet of plywood, again.
