Rio Grande baggage car
Hi guys,
Okay, off to a new project. I’m going to modify this Santa Fe baggage car from USA Trains:
Into a reasonable facsimile of this:
I’ve already installed Kadee 906 couplers. The next modification will be a larger door opening on each side:
I plan to make all new doors. Hope to get it far enough along today for paint. Dry transfer lettering and stripes are scheduled to arrive on Tuesday.
Cheers,
Matt
Not sure how you are planning to cut the door openings wider but I do know that it’s quite the task on those extruded aluminum cars. Looking forward to the results.
Any plans to remove the upper fluting?
Al P.
Maybe use a body squeegee and some J-B Weld. That will stick to the aluminum better than bondo.
Hi guys,
Got a lot done yesterday. No plans to remove the upper fluting; I decided it’s close enough and I only know two guys who will even know it’s not historically accurate.
Here is how I mounted the couplers. I note which coupler they are on them because I am old and will forget by the time I need another pair. :wink: The Kadee screws were blackened with with Jax Pewter Black to eliminate their obvious shine.
This location gets them to the correct height and also makes the diaphragms meet up properly. The diaphragms need a little trimming to make this work, but the mod is invisible once coupled up:
All of the grabirons and letter/number boards were removed. I whacked out the doors on each side to the prototypical 8’ width, using a Dremel reinforced cutoff wheel. I also added a new letterboard from K&S .016 aluminum to accommodate the taller Rio Grande lettering:
Finally I painted the body with Montana Colors RV-1028 Medium Yellow spray paint:
One of the trucks I ordered from USAT arrived broken. They have shipped me a new T-bar for repairs. Today I will make some doors from styrene. Maybe. The Broncos play today, after all. :wink:
Cheers,
Matt
Matt, I sent you a PM from MLS about the other baggage car.
Okay, not much progress this week due to home improvement projects. I cut out the four doors from styrene found in what I call my “raw materials” pile. The wider doors have four windows in them and they are not all the same size. Here is the layout:
The styrene was scribed down the middle with a #11 xacto blade to simulate where the doors meet. The windows have rounded corners; the little crosses at each corner indicate the centers of their arcs. Pilot holes were then drilled at each cross:
Each pilot hole was then drilled out with a 1/8" drill bit. I bought this little jigsaw from Micro-Mark about twenty five years ago when I thought I needed to model open engine room doors on a GP30, but don’t think I’ve used it since. The jigsaw was used to make tangent cuts to each circle:
A replacement t-bar for the trucks arrived on Tuesday, along with the lettering and stripes. Couldn’t resist putting a little of it on:
Cheers,
Matt
Nice cutting, Matt.
Those jigsaws (and other power tools) were also sold by Craftsman as “Minitools”, which I got a set of secondhand a few years back. Neat little things. Micro-Mark still offers a number of them.
Thank you Cliff.
I was asked if I had any pics of that GP30 bash. Turns out I do, looks like it was 22 years ago:
Cheers,
Matt
Hi guys,
Finally had a chance to return to this project. The new doors have all been cut out and painted. This morning I got the lettering and striping completed on one side:
I still need to install grabirons on each side of the wider door on this side, then on to the other side.
Cheers,
Matt
