Does anyone know how the 6 function outputs are configured ? Are they current sources or current sinks? If sources what is the voltage out? Full battery or regulated? If sinks what is the rating and voltage input range?
If that is too complicated try this…I desire to use one of them to trigger a relay but will need to know what coil voltage to use and how much current the output can output or input.
Thanks in advance.
