Based on an recent e-mailed sale ad from TrainWorld, I purchased a new Aristo-Craft street car – in the Los Angeles livery. Cost was near $200.00. Here is my evaluation of both the construction and running quality.
Construction:
1 - Size is 19" long x 4 1/4" high x 3" wide. The Aristo packaging declared the car to be 1:29 scale. To me, compared to the Hartland street car, it is considerably smallerl. Hartland size: 18 1/2" long x 6" high x 4 1/2" wide. I won’t run them together as the Aristo would look like “O” gauge.
I was very surprized at the “small” size compared to the Hartland street “Red Car.” However, in fairness, I did not inquire as to the actual size nor do I know if the 1:29 assessment is inaccurate. Simply, the car is noticeably smaller.
2 - Detail of the car is very good. The assembly is not complicated once the decision is made as to which screws separate the frame from the body to access the interior — there are only 4 screws to make that separation and they are the only ones recessed. The interior has seats and upright poles to accomodate standing passengers. No passengers are included. The detail appears well thought out. The paint is very well done.
3 - The frame is metal and appears to be more than adequate. The weight is 4 lbs., 4 ounces.
4 - The lighting is by leds. The passenger section has seven leds on each side of the interior providing more than enough light. There are running lights and directional headlight. The belly switches are no motor, no lights, and a choice for the cantanary system. The electronic board is easily accessable – I think the lighting has a max limitation in the electronics.
5 - The cantanary system is designed to work.
6 - Each truck is powered. On the bench the motor assemblies ran smoothly – some wobble in the axle/wheel, although it is minor. The motors appeared well-lubed. To me, the drive assembly appears complicated with the double drive/geared axles per each wheel. This evaluation is a comparison to the simplicity of the Hartland drive. My description is none other than it looks complicated, not that it is inadequate.
Problem (?)
The wheel flanges are a full 1/8" tall. When running on the 40’ of Aristo stainless track – a point-to-point set up – the car wobbled at certain points in the track. The wobbling was specific to those points which appeared to be where the track ties were attached to the rail. The wheels would actually lift up from the rail. In the 40’, about fifteen instances occured. The Hartland has LESS than 1/8" flanges and runs beautifully – so does the B’mann switcher, mining cars, the USA Gp 38 diesel, and all of the LGB locos. So my guess is the flanges are toooo large.
However, on LGB brass track and portions of Aristo’s brass track used on the 400’ of mainline, the new street car has less problems – one of the LGB 1600 turnouts gave it problems.
Question: Is there an inherent problem in the Aristo stainless track ties or is it simply too high flanges?
Soooooooooooooo. Is the remedy to file off the flange or run the flanges against a bench grinder. Taking them out of the gear system to do either will be a new one for me.
Your suggestions are welcome. Sure, I can send the car back to Aristo. If I can remedy the problem myself I give it a 100% “least hassle” award.  I am leary of horsing around with manufacturers – especially, I doubt very much that the Aristo folk have a smaller flange wheel set at the ready to send out.
OK, that’s the review. Your comments are welcome!
Wendell
