My RR was built using Aristocraft’s “wide radius” switches, mainly because they were the largest radius I could fit into the limited space I have, they were relatively cheap, and I didn’t know of any alternatives at the time.
Unfortunately they have proven to be troublesome. I don’t want get into a Aristocraft bashing session about this, and I don’t know what their most recent versions are like. But the fact is that even with extensive work on them, I can only get a train through them reliably in one direction.
This is starting to get old, as I would like to run trains the opposite direction once in a while. Also I can’t make use of the passing sidings.
So… I want to replace these switches with something more reliable. I’m wondering if the Train-Li switches would be a good choice? Or some other brand? Whichever I use, it has to fit the same space and configuration as the AC wide radius switches. But I have no idea what that translates to in the terms used by other brands, i.e., “R1, R2,” etc.
Any recommendations?
