You’re right… amps not volts…oops!
Yep, when I started, did a lot of reading before buying anything, and it’s amazing how some information can get transmogrified … (cool word)
The current ratings amazed me, but I dismissed the full stall currents because I knew I would never go there.
When I finally bought a rampmeter and spent some time watching it on my DCC setup, I felt a lot better, and the numbers were more in line with what I would expect.
I did not know about the relationship between George and AC, interesting… I was surprised to see the extent of his writeup of it on his site, but so little on other types of power, especially since it seemed he was going to DCC.
The question of rating DCC decoders, and measuring motor current is a tough one, at best an inexact science. What strikes me as funny is the wide variation in the size of heat sinks I see on these. There is a brand with a huge heatsink, which seems to have a lower current rating than another with much less cooling.
From my physics background, power is power, and if you have to dissipate X watts, then you have to have a certain amount of heat sink surface. There is no real magic to getting rid of heat if you have a passive heat sink.
Interesting stuff, and I’m still learning something new every day. Decoding these myths is fun in a way though. You should see what kind of arguments I get into when I say nicads have no memory effect, it’s usually a poor charging situation that causes the diminished discharge capacity. When I start talking conductive dendrites I usually lose my audience!
Regards, Greg
