Just a quick update on some minor work this past weekend. I made a hood for the blacksmith forge from 36 gauge sheet brass. I drew the following pattern, printed it on an inkjet printer, and glued it to the brass sheet with a glue-stick.
I cut out the shape with a pair of shears, bent it to shape on the crease lines, and washed it in warm water to remove the paper and glue residue. I soldered the seams and drilled holes in the corners for the eyebolts. These are the same 3/64” brass eyebolts that I use for my LED Receptacles. After soldering the eyebolts in position, I clipped off the excess from the inside and washed the entire assembly with hot soapy water. I etched the surfaces with a chemical brass darkening solution and spray painted it inside and out with flat black primer. I dusted the surfaces with brown and rust-colored powdered pigments and then brushed on several coats of red and black India ink/alcohol solutions (10 drops of ink per ounce of 91% isopropyl alcohol.)
I made the smoke stack from a length of 3/8” copper tubing. I used a brass darkening solution to turn it a steel-gray color and weathered it with powdered pigments. I reamed the center of a 3/8” flat steel washer for a tight fit on the copper tubing and attached it with ACC. I inserted the smoke stack up through the hole in the forge hood and attached the flat washer to the underside of the hood top with epoxy. The inside is ugly but it cannot be seen on the finished model.
I fabricated support straps for the smoke stack from 1/64” x 1/16” brass strips by bending them around a section of 3/8” copper tubing and using ACC to hold the edges together. I darkened and weathered the straps with the brass darkening solution, powdered pigments, and ink/alcohol solutions. These straps will run horizontally from the stack to the rafters. I will attach short lengths of blackened brass chain to the eyebolts on the forge hood up to the undersides of the rafters.
All that is left is to mount the hood to the rafters above the forge and make a cap for the top of the stack.
Here is the forge area where the hood will be mounted.
I added the drive belts from the overhead line shafts down to the lathe, hacksaw, grinder, and drill press. Here’s what it looks like with the belts in place.
I also added a reason for the spilled paint on the workbench. The cat knocked the can over when he jumped up to get away from the dog.
More to come later,
Bob
