I’ve trying to remove the lettering on my new loco so I can replace it with my own. So far all I have is a long list of what does NOT work:
Mineral spirits
Paint thinner
Acetone
“Goop Off”
Alcohol
Floquil and Testors thinners
Brake fluid
Bestine rubber cement thinner
Humbrol enamel thinner
Kwik-Set Activator (used to rapidly set CA type glue)
That last one sort of works. It takes the white striping off the loco pretty easily but for some reason the lettering does not come off as well. Also, it does affect the plastic a bit. So it’s not an ideal choice.
I ended up having to sand off most of the lettering, which doesn’t work very well when the lettering is on/around rivets. And although I thought I got it pretty smooth, tiny scratches show up when the gloss paint is applied.
Anyone have some other suggestions?
