The outside layout is accessed from the crawl space through a wall I cut through the inner cinder block and then the outer brick wall.
The opening is along the mortar line and is 4 bricks high by 1 brick wide.
For years I have plugged the hole with a wood block cut to fit the hole.
I have doors to a screen porch I pull up with cords and pulleys to allow entry and exit of trains but I have not figured an easy way to open the wall door because I need to open it from the outside when the trains and I are on the inside.
It’s no problem if I want to run trains outside - I just manually open & close the door.
The problem is when I am inside doing some switching & need the door open because the freight yard is too short so I need to run something outside into the screened porch. I can see what I am doing via CCTV.
It seems I either need a pulley system through the brick wall or some sort of electric door.
I have a Jeep electric window motor that may have possibilities.
Has anyone built anything like this?
Thanks,
Jerry
PS I’m writing this at the hospital while my wife is in surgery. Her broken leg has been giving me a lot of time to post about stuff I’ve been procrastinating about for years.
