We took a break for personal travel, business, school, and other hobbies, but it is time to get back at teh Triple O - 2023 Plans & Objectives. One of our first buildings, a small house, has descended over the last 3 or more years from this…
…to this…
Along the way, the original roof of sandpaper rotted off, we experimented with solar lighting, and made our first attempt at corrugated metal roofing. As the picture shows, the craft stick cladding had begun to rot away and fall off, to the point the building had passed from quaintly dilapidated to simply “broken.”
Yesterday, the 1:24 gang, Kid-zilla, and I decided to attack the project.
Prying by hand did not work, so we switched to a putty knife.
I finished what he started, and I left the debris for the 1:24 gang.
The results showed that the HardieBacker core (with its foam fillers!) had largely held up, with only one small chunk by a door falling away.
Too bad I don’t need flats for a 1:24 scale WWII diorama!
Oldest Daughter had suggested we keep this house in its Hawai’i plantation motif, and proposed making a foundation out of foam into which we could carve the supports that still hold many Hawaiian homes above ground level. The supports would get paint. The hollowed-out areas would be black to give the impression of empty space under the home. This would help set the building in time and place and take advantage of our foam skills. Golden!
The harder part is the house itself given the hodge podge of materials, and I was hoping for “vector checks” or alternatives to my thoughts below.
Repeat the Past. Part of me wants to grab the craft sticks and get gluing, but there must be some reason that the craft sticks did not hold up as well when glued to HardieBacker than those glued to foam or wood.
Clad in Plastic. Some years ago, someone had refurbished a rotting car shed by re-building it over a plexiglass core, and I am wondering if something similar could be used here, gluing the plexigalss to the HardieBacker, masking off any windows, scribing the wood paneling, and then affixing door frames and windows. I’ve no idea what glues to use here, either to affix the plexiglass to the hardiebacker or the detail bits to the plexiglass.
Clad in Wood. I am even considering wood (shudder) as the cladding to gain mastery of Sabre Saw and then scribing and gluing over that.
I’ve got a rocket to finish while this is in the ponder stage, but I hope by next weekend to start out in one of the directions above.
